Einleitung
Replace damaged keypad.
Was du brauchst
Lay the phone, screen side down, in your palm.
Slide the grey button towards the top of the phone.
With the button unlocked, grab the battery on the sides and pull up, then slide the battery up to completely remove it from the phone.
Locate four screws underneath of the battery.
Remove screws by turning counter clockwise with screwdriver until they pop out.
Place fingers on bottom of phone near charger adapter and pry back half of bottom apart.
Lift up logic board without completely removing from phone.
Remove entire keypad from beneath the logic board.
