Einleitung
This guide illustrates how to replace the keypad on the LG VX8350R.
Was du brauchst
Place the plastic opening tool at the top of the battery and pry it out to remove. Set the battery aside.
With a Phillips #00 Screwdriver, remove the four screws in a counter-clockwise direction from the back cover. Set them aside on a surface where they won't roll away; these screws will be used in reassembly.
Using the plastic opening tool, carefully pry off the back cover. You may need to use the opening tool around the entire edge of the back cover to remove completely.
When replacing the computer chip, the sensor bar for the volume button may pop out of place. If this occurs, gently push the bars back into place behind the buttons with your fingers.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
