Zum Hauptinhalt wechseln
LG VX8550 Speaker Replacement
Was du brauchst
  1. LG VX8550 Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery release up.
  2. LG VX8550 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery by lifting away from the case.
  3. LG VX8550 Speaker Replacement, Case: Schritt 3, Bild 1 von 1
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. LG VX8550 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. LG VX8550 Speaker Replacement: Schritt 5, Bild 1 von 1
    • Use the iPod opening tool to pry off the back casing.
  6. LG VX8550 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. LG VX8550 Speaker Replacement: Schritt 7, Bild 1 von 1
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. LG VX8550 Speaker Replacement, Speaker: Schritt 8, Bild 1 von 1
    • With the back casing removed the speaker is visible.
  9. LG VX8550 Speaker Replacement: Schritt 9, Bild 1 von 1
    • Lift up under top end of circuit board with the Spludger to access retaining clip.
  10. LG VX8550 Speaker Replacement: Schritt 10, Bild 1 von 1
    • Carefully pry up on retaining clip with the Spudger to release the speaker.
  11. LG VX8550 Speaker Replacement: Schritt 11, Bild 1 von 1
    • Carefully unplug speaker connector from circuit board with your fingers.
  12. LG VX8550 Speaker Replacement: Schritt 12, Bild 1 von 1
    • Remove the speaker by lifting up.
Abschluss
Nathan Jones
89 Reputation
10 Anleitungen geschrieben
Cal Poly, Team 34-55, Forte Spring 2010 Mitglied von Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 2,003
