Zum Hauptinhalt wechseln
LG VX8700 Camera Replacement
Was du brauchst
  1. LG VX8700 Camera Replacement, Battery: Schritt 1, Bild 1 von 2 LG VX8700 Camera Replacement, Battery: Schritt 1, Bild 2 von 2
    • Power the phone off.
    • Slide the back cover off using the release latch with your fingers to expose the battery.
    Frag FixBot
  2. LG VX8700 Camera Replacement: Schritt 2, Bild 1 von 2 LG VX8700 Camera Replacement: Schritt 2, Bild 2 von 2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, align the metal pins with those of the phone.
    Frag FixBot
  3. LG VX8700 Camera Replacement, Front Bezel: Schritt 3, Bild 1 von 1
    • Turn your phone around and open the flip phone. The screen is now facing you.
    • Locate the two grey rubber plugs on the bottom corners of the screen. These plugs cover up two screws.
    • Remove the two grey screw-covers.
    Frag FixBot
  4. LG VX8700 Camera Replacement: Schritt 4, Bild 1 von 2 LG VX8700 Camera Replacement: Schritt 4, Bild 2 von 2
    • Use the ejection tab at the top to remove the screen.
    • There is a gap between the case and the screen near the ear piece.
    • Insert the plastic opening tool in the gap and pry up the screen.
    • The plastic screen cover is glued onto the phone. It may be difficult to pry off.
    Frag FixBot
  5. LG VX8700 Camera Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the four corners of the screen using 3.21mm screws to separate the top cover of the phone.
    Frag FixBot
  6. LG VX8700 Camera Replacement: Schritt 6, Bild 1 von 2 LG VX8700 Camera Replacement: Schritt 6, Bild 2 von 2
    • Turn your phone around. The battery side will be facing you.
    • Insert the plastic opening tool into the groove to remove the top cover of the phone.
    • Carefully open the cover.
    Frag FixBot
  7. LG VX8700 Camera Replacement, Camera: Schritt 7, Bild 1 von 1
    • Now we have the LCD outer case off. The LCD display can be seen on the left, the camera on the right.
    • Place the phone assembly down, it is not needed anymore.
    Frag FixBot
  8. LG VX8700 Camera Replacement: Schritt 8, Bild 1 von 1
    • To remove the camera the ribbon connector should be removed.
    • This ribbon connector is glued to the case, using the plastic opening tool pry the connector off.
    Frag FixBot
  9. LG VX8700 Camera Replacement: Schritt 9, Bild 1 von 1
    • The camera should come loose after the connector is pried off.
    • Take the new camera and apply a small square of double sided tape to the new ribbon connector.
    Frag FixBot
Abschluss
Cal Poly, Team 8-16, Maness Winter 2012 Mitglied von Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 46
Insgesamt: 922
