Zum Hauptinhalt wechseln
LG VX8700 Front Bezel Replacement
Was du brauchst
  1. LG VX8700 Front Bezel Replacement, Battery: Schritt 1, Bild 1 von 2 LG VX8700 Front Bezel Replacement, Battery: Schritt 1, Bild 2 von 2
    • Power the phone off.
    • Slide the back cover off using the release latch with your fingers to expose the battery.
  2. LG VX8700 Front Bezel Replacement: Schritt 2, Bild 1 von 2 LG VX8700 Front Bezel Replacement: Schritt 2, Bild 2 von 2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, align the metal pins with those of the phone.
  3. LG VX8700 Front Bezel Replacement, Front Bezel: Schritt 3, Bild 1 von 1
    • Turn your phone around and open the flip phone. The screen is now facing you.
    • Locate the two grey rubber plugs on the bottom corners of the screen. These plugs cover up two screws.
    • Remove the two grey screw-covers.
  4. LG VX8700 Front Bezel Replacement: Schritt 4, Bild 1 von 2 LG VX8700 Front Bezel Replacement: Schritt 4, Bild 2 von 2
    • Use the ejection tab at the top to remove the screen.
    • There is a gap between the case and the screen near the ear piece.
    • Insert the plastic opening tool in the gap and pry up the screen.
    • The plastic screen cover is glued onto the phone. It may be difficult to pry off.
  5. LG VX8700 Front Bezel Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the four corners of the screen using 3.21mm screws to separate the top cover of the phone.
  6. LG VX8700 Front Bezel Replacement: Schritt 6, Bild 1 von 2 LG VX8700 Front Bezel Replacement: Schritt 6, Bild 2 von 2
    • Turn your phone around. The battery side will be facing you.
    • Insert the plastic opening tool into the groove to remove the top cover of the phone.
    • Carefully open the cover.
Abschluss
Cal Poly, Team 8-16, Maness Winter 2012 Mitglied von Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 18
Letzte 30 Tage: 66
Insgesamt: 1,303
