Zum Hauptinhalt wechseln
LG VX8700 Motherboard Replacement
Was du brauchst
  1. LG VX8700 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 LG VX8700 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Power the phone off.
    • Slide the back cover off using the release latch with your fingers to expose the battery.
  2. LG VX8700 Motherboard Replacement: Schritt 2, Bild 1 von 2 LG VX8700 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, align the metal pins with those of the phone.
  3. LG VX8700 Motherboard Replacement, Keypad: Schritt 3, Bild 1 von 2 LG VX8700 Motherboard Replacement, Keypad: Schritt 3, Bild 2 von 2
    • Remove the nine 4 mm screws from the back cover with a Phillips #0 screwdriver.
  4. LG VX8700 Motherboard Replacement: Schritt 4, Bild 1 von 2 LG VX8700 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Insert the tip of the iFixit opening tool into the small notch on the side of the case.
    • Slide the opening tool along the seam and around the edge of the phone to separate the case.
  5. LG VX8700 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Separate the two halves of the phone.
    • The back of the phone, which houses the motherboard and keypad, is displayed on the left.
    • The plastic casing is displayed on the right.
  6. LG VX8700 Motherboard Replacement: Schritt 6, Bild 1 von 3 LG VX8700 Motherboard Replacement: Schritt 6, Bild 2 von 3 LG VX8700 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Hold the phone casing with one hand and the keypad assembly with the other.
    • Separate the phone casing from the keypad/motherboard.
  7. LG VX8700 Motherboard Replacement: Schritt 7, Bild 1 von 2 LG VX8700 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Pull the two boards apart to separate the keypad from the motherboard.
  8. LG VX8700 Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 1
    • First, pull back the tape covering the connection between the motherboard and the ribbon cable.
    • Separate the connection, using the plastic opening tool.
  9. LG VX8700 Motherboard Replacement: Schritt 9, Bild 1 von 2 LG VX8700 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • After the connection is removed, the motherboard is successfully removed.
Abschluss
Cal Poly, Team 8-16, Maness Winter 2012 Mitglied von Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 1,416
