Was du brauchst
Slide the back cover off using the release latch with your fingers to expose the battery.
Lift one side of the battery using a plastic opening tool or your fingers.
Carefully remove the battery and set it aside.
Remove the nine 4 mm screws from the back cover with a Phillips #0 screwdriver.
Insert the tip of the iFixit opening tool into the small notch on the side of the case.
Slide the opening tool along the seam and around the edge of the phone to separate the case.
Hold the phone casing with one hand and the keypad assembly with the other.
Separate the phone casing from the keypad/motherboard.
First, pull back the tape covering the connection between the motherboard and the ribbon cable.
Separate the connection, using the plastic opening tool.
