Zum Hauptinhalt wechseln
LG VX9800 LCD Screens Replacement
Was du brauchst
    1. LG VX9800 LCD Screens Replacement, Front Keypad: Schritt 1, Bild 1 von 1
      • Remove the two triangular pads at the top of the two speakers.
      • These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
      Frag FixBot
      Kommentar hinzufügen
    2. LG VX9800 LCD Screens Replacement: Schritt 2, Bild 1 von 1
      • Remove the two rubber cylinders from their shafts. These cover more screws.
      • This requires a little more effort, so you may need to "dig" them out.
      Frag FixBot
    3. LG VX9800 LCD Screens Replacement: Schritt 3, Bild 1 von 1
      • Now remove the four screws.
      • The screws are small, so put them somewhere that you can easily keep track of them.
      Frag FixBot
    4. LG VX9800 LCD Screens Replacement: Schritt 4, Bild 1 von 1
      • Starting on the side with red square, pry the faceplate upwards with the flat end of a spudger.
      • Continue to slide the flat edge along the seam of the faceplate.
      • You should hear popping or snapping noises as the faceplate is being removed.
      Frag FixBot
    5. LG VX9800 LCD Screens Replacement: Schritt 5, Bild 1 von 2 LG VX9800 LCD Screens Replacement: Schritt 5, Bild 2 von 2
      • The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
      • Lift the dislodged faceplate off the motherboard while being mindful of the wires still attached to it.
      Frag FixBot
    6. LG VX9800 LCD Screens Replacement: Schritt 6, Bild 1 von 3 LG VX9800 LCD Screens Replacement: Schritt 6, Bild 2 von 3 LG VX9800 LCD Screens Replacement: Schritt 6, Bild 3 von 3
      • The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
      • Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
      • This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
      Frag FixBot
    7. LG VX9800 LCD Screens Replacement: Schritt 7, Bild 1 von 1
      • The faceplate and keypad can now be completely removed from the phone.
      Frag FixBot
    1. LG VX9800 LCD Screens Replacement, LCD Screens: Schritt 8, Bild 1 von 3 LG VX9800 LCD Screens Replacement, LCD Screens: Schritt 8, Bild 2 von 3 LG VX9800 LCD Screens Replacement, LCD Screens: Schritt 8, Bild 3 von 3
      • Wedge the spudger into the small gap between the phone and the metal casing of the motherboard.
      • Slide the spudger underneath the metal and along the edge. The motherboard should begin to rise.
      • There is a ribbon at the end of this groove, do not slide the spudger into the ribbon.
      • Now use the spudger to lift the other side of the motherboard.
      Frag FixBot
    2. LG VX9800 LCD Screens Replacement: Schritt 9, Bild 1 von 1
      • Lift the motherboard at an angle.
      • Do not completely remove the motherboard. Doing so will tear the ribbon!
      Frag FixBot
    3. LG VX9800 LCD Screens Replacement: Schritt 10, Bild 1 von 2 LG VX9800 LCD Screens Replacement: Schritt 10, Bild 2 von 2
      • Gently pull the LCD screen upwards.
      • It can be tricky do this, you may want to use a spudger to pry it up if it doesn't pull up easily.
      • Remove the speaker wires from the LCD screen.
      • Replace the LCD screen and solder the wires to the new screen.
      • This step requires soldering. Only do this step if you are OK with soldering small wires. Look at this guide for help with soldering.
      Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 16-32, Maness Winter 2010 Mitglied von Cal Poly, Team 16-32, Maness Winter 2010
CPSU-MANESS-W10S16G32
4 Mitglieder
44 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 2,643
