Zum Hauptinhalt wechseln
LG VX9800 Logic Board Replacement
Was du brauchst
  1. LG VX9800 Logic Board Replacement, Front Keypad: Schritt 1, Bild 1 von 1
    • Remove the two triangular pads at the top of the two speakers.
    • These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
  2. LG VX9800 Logic Board Replacement: Schritt 2, Bild 1 von 1
    • Remove the two rubber cylinders from their shafts. These cover more screws.
    • This requires a little more effort, so you may need to "dig" them out.
  3. LG VX9800 Logic Board Replacement: Schritt 3, Bild 1 von 1
    • Now remove the four screws.
    • The screws are small, so put them somewhere that you can easily keep track of them.
  4. LG VX9800 Logic Board Replacement: Schritt 4, Bild 1 von 1
    • Starting on the side with blue square, pry the faceplate upwards with the flat end of a spudger.
    • Continue to slide the flat edge along the seam of the faceplate.
    • You should hear popping or snapping noises as the faceplate is being removed.
  5. LG VX9800 Logic Board Replacement: Schritt 5, Bild 1 von 2 LG VX9800 Logic Board Replacement: Schritt 5, Bild 2 von 2
    • The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
  6. LG VX9800 Logic Board Replacement: Schritt 6, Bild 1 von 3 LG VX9800 Logic Board Replacement: Schritt 6, Bild 2 von 3 LG VX9800 Logic Board Replacement: Schritt 6, Bild 3 von 3
    • The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
    • Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
    • This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
  7. LG VX9800 Logic Board Replacement: Schritt 7, Bild 1 von 1
    • The faceplate and keypad can now be completely removed from the phone.
  8. LG VX9800 Logic Board Replacement, Logic Board: Schritt 8, Bild 1 von 3 LG VX9800 Logic Board Replacement, Logic Board: Schritt 8, Bild 2 von 3 LG VX9800 Logic Board Replacement, Logic Board: Schritt 8, Bild 3 von 3
    • Use Spudger to pry against the side side of the phone and the logic board to release it.
    • The logic board is connected to a thin silver piece of metal highlighted with a blue square in the photo. Pry against this piece and the phone to release the board.
    • The logic board is connected to the phone and speaker with the set of connections highlighted with a red circle. Do not yank on the board once its released
  9. LG VX9800 Logic Board Replacement: Schritt 9, Bild 1 von 1
    • Remove 4 wires from logic board. Replace board by soldering back the 4 wires and you're done!
    • This step requires soldering. Only do this step if you are OK with soldering small wires.
Ziellinie
Steven Clark
29 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 16-32, Maness Winter 2010 Mitglied von Cal Poly, Team 16-32, Maness Winter 2010
CPSU-MANESS-W10S16G32
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 1,562
