Einleitung
If your front screen, keyboard or speakers stop working you may need to replace your logic board. Follow this guide to do it.
Was du brauchst
Remove the two triangular pads at the top of the two speakers.
These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
Remove the two rubber cylinders from their shafts. These cover more screws.
This requires a little more effort, so you may need to "dig" them out.
Starting on the side with red square, pry the faceplate upwards with the flat end of a spudger.
Continue to slide the flat edge along the seam of the faceplate.
Lift the dislodged faceplate off the motherboard while being mindful of the wires still attached to it.
The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
Use Spudger to pry against the side side of the phone and the logic board to release it.
The logic board is connected to a thin silver piece of metal highlighted with a blue square in the photo. Pry against this piece and the phone to release the board.
Remove 4 wires from logic board. Replace board by soldering back the 4 wires and you're done!
