Einleitung
The charging port of any device is a vital component for the life of the device. This guide will help you replace the charging port of the LG Volt.
Was du brauchst
Remove all 11 (4mm) screws with the JIS #000 screwdriver
There are three screws on top, three above the battery, one next to the battery, one under the battery and three at the bottom of the phone.
Use the plastic opening tool to remove the back housing from the frame of the phone.
Use a JIS #000 screwdriver to remove the 1 screw (4mm) on right side under copper tab.
Use a JIS #000 screwdriver to remove the screw (4mm) on bottom left under battery tray.
Disconnect the white and black cables as indicated.
Lift indicated flap as shown.
Use the plastic opening tool to carefully lift the charger assembly from the phone.
Start from the copper tab and continue in a clockwise direction.
Once it is loose remove the assembly from the phone.
Put a new charging port in place of old charging port.
Follow steps 8 through 1 in that order for reassembly.
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare
Great guide with excellent pictures
Hi, I replaced mine, but I don’t think it’s working - what voltages should be present on which pins (at the battery connection) when it’s plugged in?
