Einleitung
The power button for the LG Volt is located at the right side of the device. Use this guide to replace the button of the LG Volt.
Was du brauchst
Use the plastic opening tool to remove the back housing from the frame of the phone.
Use the precision tweezers set to gently lift the rubber tab off its anchor.
Then push the power button through the cutout to remove completely.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
