Zum Hauptinhalt wechseln
LG Watch Urbane Battery Replacement
Was du brauchst
  1. LG Watch Urbane Battery Replacement, Battery: Schritt 1, Bild 1 von 2 LG Watch Urbane Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push on the band in order to expose the pins
    • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
  2. LG Watch Urbane Battery Replacement: Schritt 2, Bild 1 von 2 LG Watch Urbane Battery Replacement: Schritt 2, Bild 2 von 2
    • Using plastic opening tools, carefully pry open the back cover of the the watch.
    • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
  3. LG Watch Urbane Battery Replacement: Schritt 3, Bild 1 von 3 LG Watch Urbane Battery Replacement: Schritt 3, Bild 2 von 3 LG Watch Urbane Battery Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    Kaufen
    • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
    • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
    • Using plastic opening tools, remove the four connectors attached to the motherboard
  4. LG Watch Urbane Battery Replacement: Schritt 4, Bild 1 von 3 LG Watch Urbane Battery Replacement: Schritt 4, Bild 2 von 3 LG Watch Urbane Battery Replacement: Schritt 4, Bild 3 von 3
    • Using the plastic opening tools, carefully lift up the motherboard.
    • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
Abschluss
18 weitere Nutzer:innen haben diese Anleitung absolviert.
Rey Diaz
699 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 1-4, Remmell Fall 2015 Mitglied von USF Tampa, Team 1-4, Remmell Fall 2015
USFT-REMMELL-F15S1G4
4 Mitglieder
4 Anleitungen geschrieben
11 Kommentare
"pried" not "pryed"
Patty Remmell - Antwort
Where do I find a replacement battery?
nickpfau - Antwort
Found mine on ebay. Search for BL-S3 battery.
Atreidae -
The reassembly requires gluing the back together. How do you get the glue?
jiteshshahin - Antwort
There is glue around cover. I suppose when closing we should add glue to be waterproof again? Nothing about it in the guide, beside that ok.
Imx - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 39
Insgesamt: 15,362
