Einleitung
In order to replace your screen you are going to need the proper tools. There are screws that need to be unscrewed and components that need to be pried open carefully. The tools needed will be plastic opening tools, PH #000 screwdriver and tweezers. With these prepared everything should be ready to start the replacement of the screen for the LG Watch Urbane.
Was du brauchst
Using plastic opening tools, carefully pry open the back cover of the the watch.
In diesem Schritt verwendetes Werkzeug:Magnetic Project Mat$19.95
Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
Using plastic opening tools, remove the four connectors attached to the motherboard
Using the plastic opening tools, carefully lift up the motherboard.
IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
Now that you have removed the motherboard and battery, it is time to remove the dock connector.
Using a PH000 screwdriver, remove the two screws in order to release the dock connector from the watch.
Once the screws are removed, the dock connector is free to be moved.
Gently lift the dock connector away from the frame and you will now be able to see the screen.
The watch's screen is stuck to the back of the glass with an adhesive so be tedious when pulling it off.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
where i can find watch urbane display ?
Does anyone know where to buy the display?
