Einleitung
This guide to help you replace the damaged battery to restore your LG X Power back to its former glory.
Ersatzteile
Keine Ersatzteile angegeben.
Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
Pull the cameras out to remove them.
Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
3 weitere Nutzer haben diese Anleitung absolviert.
3 Kommentare
lg x power mobail sarkit board+ bettery kaha pe milegi
Were can i buy the battery?
thx for rundown
