Zum Hauptinhalt wechseln
Einleitung
This guide to help you replace the damaged battery to restore your LG X Power back to its former glory.
  1. Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off. Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. Remove the twelve 2.5mm Phillips #0 screws from the back of the phone. Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click. With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  5. Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard. Pull the cameras out to remove them. Pull the cameras out to remove them.
    • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
    • Pull the cameras out to remove them.
  6. Use the flat end of a spudger to disconnect the battery from the motherboard.
    • Use the flat end of a spudger to disconnect the battery from the motherboard.
    • You will not be removing anything, just disconnecting.
  7. Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
    • Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
  8. Use a spudger and plastic opening tool to carefully pry up the battery. There is a strong adhesive on the back of the battery that will make it difficult to remove.
    • Use a spudger and plastic opening tool to carefully pry up the battery.
    • There is a strong adhesive on the back of the battery that will make it difficult to remove.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Chad Sears
812 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S3-G6, Nance Spring 2018 Mitglied von USF Tampa, Team S3-G6, Nance Spring 2018
USFT-NANCE-S18S3G6
3 Mitglieder
6 Anleitungen geschrieben
lg x power mobail sarkit board+ bettery kaha pe milegi
HASIBUL RAHAMAN - Antwort
Were can i buy the battery?
Tasha Boost - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 13
Letzte 7 Tage: 119
Letzte 30 Tage: 622
Insgesamt: 7,105
