Einleitung
This guide will show you how to replace the charging port on a LG X Power smartphone.
Was du brauchst
Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
Pull the cameras out to remove them.
Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Where can i get the charging port part? There are so many different usb female ports.
