Zum Hauptinhalt wechseln
Einleitung
You will be accessing the inside components through this guide but not replacing anything. You will need to complete this before replacing anything on the phone.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off. Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  3. Remove the twelve 2.5mm Phillips #0 screws from the back of the phone. Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  4. Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click. With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Chad Sears
833 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S3-G6, Nance Spring 2018 Mitglied von USF Tampa, Team S3-G6, Nance Spring 2018
USFT-NANCE-S18S3G6
3 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 3
Letzte 7 Tage: 18
Letzte 30 Tage: 86
Insgesamt: 1,514
