Einleitung
This guide will show you how to replace the top speaker on the LG X Style smart phone. This is used if the speaker blows out or stops working.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Power down the device and make sure that it is turned off.
Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
Gently twist tool clockwise until the back case pops open [this will create a small gap].
Slide the tool along the gap around the entire device.
Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
Create a gap with plastic opening tool by applying pressure between glass screen and plastic edge of device.
Slide prying tool around entire device beginning toward the top.
Lift off and remove the screen from the device.
Using the plastic opening tool, carefully slide the edge of the tool under the press fit cable connections and lift up to disconnect. Do this for all three ribbon cables.
Using the iFixit opening tool, remove the motherboard from the screen by inserting the opening tool under the edge of the motherboard and lifting up.
Use the nylon-tip reverse tweezers to remove the front facing speaker.
Ein weiterer Nutzer hat diese Anleitung absolviert.
