Zum Hauptinhalt wechseln
LG Xenon Motherboard Replacement
Was du brauchst
  1. LG Xenon Motherboard Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Turn the phone over so the back side is facing you.
  2. LG Xenon Motherboard Replacement: Schritt 2, Bild 1 von 2 LG Xenon Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Placing your thumb on the bottom of the phone, apply pressure to the small ridge in the middle of the phone and push upward towards the camera.
    • The back casing should slide off.
  3. LG Xenon Motherboard Replacement, Battery: Schritt 3, Bild 1 von 2 LG Xenon Motherboard Replacement, Battery: Schritt 3, Bild 2 von 2
    • Using your index finger, pull the top of the battery out first. Place your finger at the top center of the battery in the gap that is provided. Then pull the battery towards yourself.
    • The battery should easily fall out after the top of the battery has been pulled out.
  4. LG Xenon Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 2 LG Xenon Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 2
    • Unscrew the six 2.4mm Phillips #00 screws (three on the left and three on the right of the phone) to remove the inner back case.
  5. LG Xenon Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Once all six screws are removed, use the plastic opening tool to carefully pry apart the inner back case. Push the plastic tool underneath the case. Carefully push upward, with the tool, while moving it around the case.
  6. LG Xenon Motherboard Replacement: Schritt 6, Bild 1 von 2 LG Xenon Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Remove the camera, lock, and volume buttons from the side of the phone.
  7. LG Xenon Motherboard Replacement: Schritt 7, Bild 1 von 2 LG Xenon Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Carefully remove the two 3mm Phillips #00 screws (one on the top and one on the bottom) that are attaching the motherboard to the phone.
  8. LG Xenon Motherboard Replacement: Schritt 8, Bild 1 von 2 LG Xenon Motherboard Replacement: Schritt 8, Bild 2 von 2
    • For this next step, carefully lift and remove the motherboard.
    • A connector cable will still be connected to the motherboard upon removing it.
    • Damage to the connector cable will permanently disable phone.
  9. LG Xenon Motherboard Replacement: Schritt 9, Bild 1 von 2 LG Xenon Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Carefully unclip the silver metallic tab from the motherboard.
  10. LG Xenon Motherboard Replacement: Schritt 10, Bild 1 von 2 LG Xenon Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Once the cable is removed, you have successfully disassembled the motherboard of your phone.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Micaela Saqui
39 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 9-41, Regan Spring 2012 Mitglied von Cal Poly, Team 9-41, Regan Spring 2012
CPSU-REGAN-S12S9G41
5 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 3
Insgesamt: 1,042
