Zum Hauptinhalt wechseln
Einleitung
In this guide you will be removing the back panel from the rest of the phone.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Before dissembling your phone, be sure it is powered off to avoid minor electric shock or possible fire. Place the phone facedown on the table. Use your fingernail (or a small screw driver) to pull down the tab below the battery.
    • Before dissembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone facedown on the table.
    • Use your fingernail (or a small screw driver) to pull down the tab below the battery.
    • Lift the battery out.
  2. Locate the five rubber covers on the back panel of the phone. Use the metal probe to pop out each rubber cover to reveal the screws underneath.
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  4. Locate the six 2.5mm screws on the back panel of the phone. Use a #00 Phillips screwdriver to remove each 2.5mm screw.
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  5. Locate the seam around the edge of the phone. Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Reed Williston
34 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 16-55, Forte Fall 2012 Mitglied von Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Mitglieder
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 601
