Zum Hauptinhalt wechseln
LG env2 vx9100 Camera Replacement
Was du brauchst
  1. LG env2 vx9100 Camera Replacement, Battery: Schritt 1, Bild 1 von 3 LG env2 vx9100 Camera Replacement, Battery: Schritt 1, Bild 2 von 3 LG env2 vx9100 Camera Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before disassembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone face down on the table.
    • Use your fingernail or an opening tool to pull down the tab below the battery.
    • Lift the battery out.
  2. LG env2 vx9100 Camera Replacement, Back Panel: Schritt 2, Bild 1 von 2 LG env2 vx9100 Camera Replacement, Back Panel: Schritt 2, Bild 2 von 2
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. LG env2 vx9100 Camera Replacement: Schritt 3, Bild 1 von 2 LG env2 vx9100 Camera Replacement: Schritt 3, Bild 2 von 2
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  4. LG env2 vx9100 Camera Replacement: Schritt 4, Bild 1 von 2 LG env2 vx9100 Camera Replacement: Schritt 4, Bild 2 von 2
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
  5. LG env2 vx9100 Camera Replacement, Camera: Schritt 5, Bild 1 von 2 LG env2 vx9100 Camera Replacement, Camera: Schritt 5, Bild 2 von 2
    • Locate the ribbon attached to the lens of the camera.
    • Place the plastic opening tool in between the logic board and ribbon.
    • Lift up the plastic opening to detach the ribbon from the logic board.
  6. LG env2 vx9100 Camera Replacement: Schritt 6, Bild 1 von 2 LG env2 vx9100 Camera Replacement: Schritt 6, Bild 2 von 2
    • Place the plastic opening tool in between the lens and the logic board.
    • Detach the lens from the logic board using the plastic opening tool by popping it out.
    • Take the entire lens and ribbon off of the logic board.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 16-55, Forte Fall 2012 Mitglied von Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 454
