Zum Hauptinhalt wechseln
LG env2 vx9100 Inside Keyboard Replacement
Was du brauchst
  1. LG env2 vx9100 Inside Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 LG env2 vx9100 Inside Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 LG env2 vx9100 Inside Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before disassembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone face down on the table.
    • Use your fingernail or an opening tool to pull down the tab below the battery.
    • Lift the battery out.
  2. LG env2 vx9100 Inside Keyboard Replacement, Back Panel: Schritt 2, Bild 1 von 2 LG env2 vx9100 Inside Keyboard Replacement, Back Panel: Schritt 2, Bild 2 von 2
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. LG env2 vx9100 Inside Keyboard Replacement: Schritt 3, Bild 1 von 2 LG env2 vx9100 Inside Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  4. LG env2 vx9100 Inside Keyboard Replacement: Schritt 4, Bild 1 von 2 LG env2 vx9100 Inside Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
  5. LG env2 vx9100 Inside Keyboard Replacement, Inside Keyboard: Schritt 5, Bild 1 von 3 LG env2 vx9100 Inside Keyboard Replacement, Inside Keyboard: Schritt 5, Bild 2 von 3 LG env2 vx9100 Inside Keyboard Replacement, Inside Keyboard: Schritt 5, Bild 3 von 3
    • Locate the silver strip connected to the logic board. The silver strip is closest to the bottom hinge of the phone.
    • Wedge the plastic opening tool in between the silver strip and the logic board.
    • Lift the plastic opening tool to separate the silver strip from the logic board.
  6. LG env2 vx9100 Inside Keyboard Replacement: Schritt 6, Bild 1 von 2 LG env2 vx9100 Inside Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Wedge the plastic opening tool in between the logic board and the phone.
    • Lift the plastic opening tool to separate the logic board from the phone.
  7. LG env2 vx9100 Inside Keyboard Replacement: Schritt 7, Bild 1 von 2 LG env2 vx9100 Inside Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Locate the back of the inside keyboard.
    • Take out the inside keyboard. You may need to use your fingernail to pull one of the corners up.
Abschluss
Cal Poly, Team 16-55, Forte Fall 2012 Mitglied von Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 877
