Einleitung
In this guide you will be taking off the back panel to access and remove the side volume and camera buttons.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Before dissembling your phone, be sure it is powered off to avoid minor electric shock or possible fire. Place the phone facedown on the table. Use your fingernail (or a small screw driver) to pull down the tab below the battery.
    • Before dissembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone facedown on the table.
    • Use your fingernail (or a small screw driver) to pull down the tab below the battery.
    • Lift the battery out.
  2. Locate the five rubber covers on the back panel of the phone. Use the metal probe to pop out each rubber cover to reveal the screws underneath.
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Locate the six 2.5mm screws on the back panel of the phone. Use a #00 Phillips screwdriver to remove each 2.5mm screw.
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  5. Locate the seam around the edge of the phone. Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
  6. Locate the volume and camera buttons on the right side of the phone. Lift up on the buttons to slide them out of the phone.
    • Locate the volume and camera buttons on the right side of the phone.
    • Lift up on the buttons to slide them out of the phone.
Abschluss
Reed Williston
34 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 16-55, Forte Fall 2012 Mitglied von Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Mitglieder
14 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 411
