Einleitung
In this guide you will be taking off the back panel to access and remove the side volume and camera buttons.
Was du brauchst
Place the phone face down on the table.
Pull down the tab below the battery with your fingernail or an opening tool.
Lift the battery out.
Locate the five rubber covers on the back panel of the phone.
Use a metal probe to remove each rubber cover and expose the screws underneath.
Locate the six 2.5-millimeter Phillips #00 screws on the back panel.
Remove all six screws with a Phillips #00 screwdriver.
Locate the seam around the edge of the phone.
Insert a plastic opening tool into the seam and gently pry to release the tabs.
Work around the phone until all tabs are released.
Remove the back panel.
Locate the volume and camera buttons on the right side of the phone.
Lift up on the buttons to slide them out of the phone.
