Zum Hauptinhalt wechseln
LG-P970 touch screen Replacement
Was du brauchst
  1. LG-P970 touch screen Replacement, touch screen: Schritt 1, Bild 1 von 3 LG-P970 touch screen Replacement, touch screen: Schritt 1, Bild 2 von 3 LG-P970 touch screen Replacement, touch screen: Schritt 1, Bild 3 von 3
    • remove the back cover
    • remove the battery
    • remove the SIM card
    • remove the µSD card (Memory)
  2. LG-P970 touch screen Replacement: Schritt 2, Bild 1 von 3 LG-P970 touch screen Replacement: Schritt 2, Bild 2 von 3 LG-P970 touch screen Replacement: Schritt 2, Bild 3 von 3
    • remove 7 screws on the back
    • with a tool start to open the back frame
    • and it's now easy to remove the back frame with hand, carefully
  3. LG-P970 touch screen Replacement: Schritt 3, Bild 1 von 3 LG-P970 touch screen Replacement: Schritt 3, Bild 2 von 3 LG-P970 touch screen Replacement: Schritt 3, Bild 3 von 3
    • remove buttons
    • locate the back camera
    • with a tool raise up the led.carefully
  4. LG-P970 touch screen Replacement: Schritt 4, Bild 1 von 3 LG-P970 touch screen Replacement: Schritt 4, Bild 2 von 3 LG-P970 touch screen Replacement: Schritt 4, Bild 3 von 3
    • with a tool disconnect the back camera
    • and remove the camera with your fingers.
  5. LG-P970 touch screen Replacement: Schritt 5, Bild 1 von 2 LG-P970 touch screen Replacement: Schritt 5, Bild 2 von 2
    • don't forget to remove the little connector of screen, with a tool, right next to the empty slot of the camera.
  6. LG-P970 touch screen Replacement: Schritt 6, Bild 1 von 3 LG-P970 touch screen Replacement: Schritt 6, Bild 2 von 3 LG-P970 touch screen Replacement: Schritt 6, Bild 3 von 3
    • It's time to remove carefully the tactile screen.
    • don't scratch le LCD!!!
  7. LG-P970 touch screen Replacement: Schritt 7, Bild 1 von 3 LG-P970 touch screen Replacement: Schritt 7, Bild 2 von 3 LG-P970 touch screen Replacement: Schritt 7, Bild 3 von 3
    • the touch panel is glued with double-sided tape. You can remove it with your fingers. carefull with the touch screen connector.
    • cut new double sided tape (1-2mm width), put it on the are and peel it.
  8. LG-P970 touch screen Replacement: Schritt 8, Bild 1 von 3 LG-P970 touch screen Replacement: Schritt 8, Bild 2 von 3 LG-P970 touch screen Replacement: Schritt 8, Bild 3 von 3
    • remove the inside protection on the new touch screen.
    • carefully put the news touch screen on the LG. Take care that the connector goes right through the right hole.
    • to finish, add all part by reading these instructions in reverse ;-)
    • and try if it work !
Abschluss
19 weitere Nutzer:innen haben diese Anleitung absolviert.
Fox4EGX
545 Reputation
1 Anleitung geschrieben
Ein Kommentar
Hi. To take the screws out do I need a phillips? Thanks.
schutze61 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 9,685
