Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
  1. Remove the two plastic screw covers below the inside phone screen. Remove the two plastic screw covers below the inside phone screen.
    • Remove the two plastic screw covers below the inside phone screen.
  2. Unscrew both screws using a Torx T6 screwdriver.
    • Unscrew both screws using a Torx T6 screwdriver.
  3. Pry off the screen front cover with a 3mm flathead screwdriver. Pry off the screen front cover with a 3mm flathead screwdriver. Pry off the screen front cover with a 3mm flathead screwdriver.
    • Pry off the screen front cover with a 3mm flathead screwdriver.
  4. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  5. Pry off the speaker, which is glued onto the front cover, using a small flathead screwdriver. Pry off the speaker, which is glued onto the front cover, using a small flathead screwdriver. Pry off the speaker, which is glued onto the front cover, using a small flathead screwdriver.
    • Pry off the speaker, which is glued onto the front cover, using a small flathead screwdriver.
  6. Unsolder the black and red wires of the speaker from where they are attached to the base of the screen.
    • Unsolder the black and red wires of the speaker from where they are attached to the base of the screen.
  7. Obtain replacement speaker and solder the new black and red wires back to the base of the screen.
    • Obtain replacement speaker and solder the new black and red wires back to the base of the screen.
  8. Apply glue to the back of the speaker and place it back in its original position.
    • Apply glue to the back of the speaker and place it back in its original position.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Nicholas Schmidt
97 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 3-25, Regan Fall 2010 Mitglied von Cal Poly, Team 3-25, Regan Fall 2010
CPSU-REGAN-F10S3G25
4 Mitglieder
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 4
Insgesamt: 749
