Was du brauchst
Remove the rubber case around the drive. You can just stretch it off.
Push on one side of the drive, where the white plastic is. Which side does not matter.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
Thanks for confirming the T8 Torx security bit - I had to buy a set!
Andy, how are you. ?
Am facing the same issue, did fixed yours ?
Hello, I have this same drive. My hard drive is fine, the internal case that has the SATA to USB C connector isn’t working. Is there a replacement for the adapter/inner case & the adapter?
I have no idea of replacement of the LaCie internal case
But any generic USB C To SATA Adapter can be used - and very cheap on amazon too
Like in this link for example
Eoin -
