Zum Hauptinhalt wechseln
Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement
Was du brauchst
  1. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement, Hose: Schritt 1, Bild 1 von 1
    • Place the hair dryer on a sturdy surface with its backside facing up.
    • Using a Phillips #1 screwdriver, remove the six 12.7 mm screws from the back of the hair dryer.
  2. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 2, Bild 1 von 1
    • Open the hair dryer, and place the front cover to the side.
  3. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 3, Bild 1 von 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 3, Bild 2 von 2
    • Disconnect the clear tube from the hose cuff.
  4. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 4, Bild 1 von 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 4, Bild 2 von 2
    • Untwist the hose cuff off the fan opening.
  5. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 5, Bild 1 von 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 5, Bild 2 von 2
    • Pull the hose through the hose cuff until it reaches the top of the inner rim.
  6. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 6, Bild 1 von 1
    • Place and twist the hose cuff onto the fan opening.
  7. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 7, Bild 1 von 3 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 7, Bild 2 von 3 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 7, Bild 3 von 3
    • Slide the hose through the clear tube.
    • Slide the clear tube until it meets the rim of the hose cuff.
  8. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 8, Bild 1 von 1
    • Place the hair dryer's front cover on top of the back cover, leaving a finger's width space for the next step.
  9. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 9, Bild 1 von 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 9, Bild 2 von 2
    • Align the wire cover to the grooves of the left and right sides of the hair dryer.
    • Pull the cord through the wire opening.
    • Lightly press on the wire cover to secure its placement.
    • Push the front cover down to close the hair dryer.
  10. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 10, Bild 1 von 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 10, Bild 2 von 2
    • Carefully flip the hair dryer on its backside.
    • Place a screw in each opening, and screw them until secure.
  11. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: Schritt 11, Bild 1 von 1
    • Gently pull the hose to ensure it is secure.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Please provide resource for purchasing a replacement bonnet for the Laila Ali LADR5604
Joyce Johnson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 26
Insgesamt: 741
