Zum Hauptinhalt wechseln
Land Yachtz Longboard Kingpin Replacement
Was du brauchst
  1. Land Yachtz Longboard Kingpin Replacement, Kingpin: Schritt 1, Bild 1 von 3 Land Yachtz Longboard Kingpin Replacement, Kingpin: Schritt 1, Bild 2 von 3 Land Yachtz Longboard Kingpin Replacement, Kingpin: Schritt 1, Bild 3 von 3
    • Use a 3/8" socket wrench, adjustable wrench, or skate tool to take off all 4 of the screws holding the truck to the board.
  2. Land Yachtz Longboard Kingpin Replacement: Schritt 2, Bild 1 von 2 Land Yachtz Longboard Kingpin Replacement: Schritt 2, Bild 2 von 2
    • Use a skate tool or a 1/2" socket wrench to remove the wheel nut and take the wheels off of the truck.
  3. Land Yachtz Longboard Kingpin Replacement: Schritt 3, Bild 1 von 3 Land Yachtz Longboard Kingpin Replacement: Schritt 3, Bild 2 von 3 Land Yachtz Longboard Kingpin Replacement: Schritt 3, Bild 3 von 3
    • Take off the first nut securing the axle of the truck to the kingpin.
    • Remove the axle of the truck from the truck fastener.
    • Remove the second nut securing the kingpin in place.
  4. Land Yachtz Longboard Kingpin Replacement: Schritt 4, Bild 1 von 2 Land Yachtz Longboard Kingpin Replacement: Schritt 4, Bild 2 von 2
    • Remove the faulty kingpin from the truck.
  5. Land Yachtz Longboard Kingpin Replacement: Schritt 5, Bild 1 von 1
    • If the kingpin is stuck in the truck, firmly hammer it to get it loose.
    • Be careful not to hit your hand with the hammer. If your finger joints are placed in an awkward position, even an accidental hit from the hammer can cause injury.
  6. Land Yachtz Longboard Kingpin Replacement: Schritt 6, Bild 1 von 2 Land Yachtz Longboard Kingpin Replacement: Schritt 6, Bild 2 von 2
    • Insert the new kingpin and hammer it in if needed.
    • Be careful of your fingers when hammering the kingpin back in. Injury can result from even a glancing hit.
  7. Land Yachtz Longboard Kingpin Replacement: Schritt 7, Bild 1 von 3 Land Yachtz Longboard Kingpin Replacement: Schritt 7, Bild 2 von 3 Land Yachtz Longboard Kingpin Replacement: Schritt 7, Bild 3 von 3
    • Put the nut that secures the kingpin back in place.
    • Put the axle back on the truck and kingpin.
    • Put the final nut back onto the kingpin to secure it to the axle.
  8. Land Yachtz Longboard Kingpin Replacement: Schritt 8, Bild 1 von 1
    • Tighten the nut on the kingpin using a 9/16" socket wrench or skate tool.
  9. Land Yachtz Longboard Kingpin Replacement: Schritt 9, Bild 1 von 2 Land Yachtz Longboard Kingpin Replacement: Schritt 9, Bild 2 von 2
    • Reattach the wheels to the truck using the 1/2" socket wrench or skate tool.
  10. Land Yachtz Longboard Kingpin Replacement: Schritt 10, Bild 1 von 3 Land Yachtz Longboard Kingpin Replacement: Schritt 10, Bild 2 von 3 Land Yachtz Longboard Kingpin Replacement: Schritt 10, Bild 3 von 3
    • Reattach the truck to the skateboard using Phillips #1 screwdriver and 3/8" socket wrench or skate tool to screw the nut back on the screw.
    • Be sure that the kingpin is facing the end of the board when putting the trucks back on.
Abschluss
Test out your longboard and make sure that you can tighten and loosen the trucks effectively. Take it for a ride and make sure that turning works as you expect it to. If the problem persists, double-check to make sure that everything is put on correctly and the nuts are all securely fastened.
Max Badal
181 Reputation
1 Anleitung geschrieben
UC Davis, Team 2-2, Morris Winter 2023 Mitglied von UC Davis, Team 2-2, Morris Winter 2023
UCD-MORRIS-W23S2G2
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 184
