Einleitung
This is my guide on how to open a 20” Lasko Wind Fan to remove or replace the blade. This guide can increase the life of the fan. It also shows you how to access the inside of the fan to clean it. This is helpful for dust build up, and prolonging the life of your fan. Also, replacing the blade can increase the life span. Be sure to turn off and unplug this device before cleaning or placing your inside of it.
Was du brauchst
Use the Phillips #0 screwdriver to remove four 8.8 mm screws that are marked on the back of the grill.
Grab both sides of the blade and twist counter clockwise to remove it from the base axel attached to the back grill.
3 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
Recherche moteur lasko windmachin 3300
Recherche moteur lasko windmachine 3300
I HAVE TWO BOUTH DIED TWO DAY LESS THEN 2 YEARS OLD MJSKPH45@GMAIL.COM am not happy over 50 each
