Zum Hauptinhalt wechseln
Lasko 2002W Motor Replacement
Was du brauchst
  1. Lasko 2002W Motor Replacement, Remove cover: Schritt 1, Bild 1 von 1
    • Remove the front cage from the fan, exposing the screws.
  2. Lasko 2002W Motor Replacement, Remove screws: Schritt 2, Bild 1 von 1
    • Remove the 3 screws holding the fan on to the motor housing using a 3/16" philips head screw driver. The length of the screwdriver does not matter.
  3. Lasko 2002W Motor Replacement, Remove motor screws: Schritt 3, Bild 1 von 1
    • Remove the screws holding the motor onto the fan using the same 3/16" phillips head screwdriver. There are two screws.
    • Once removed, remove the metal part the screws were holding to the motor.
  4. Lasko 2002W Motor Replacement, Remove old motor.: Schritt 4, Bild 1 von 1
    • Remove the old motor from the fan. No tools are required. The motor can simply be pulled out.
  5. Lasko 2002W Motor Replacement, Place new motor in motor housing.: Schritt 5, Bild 1 von 1
    • Now that the old motor is removed, a new motor can be placed in the motor housing.
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
elsa
382 Reputation
1 Anleitung geschrieben
USF Tampa, Team 1-39, Donnelly Fall 2014 Mitglied von USF Tampa, Team 1-39, Donnelly Fall 2014
USFT-DONNELLY-F14S1G39
1 Mitglied
Ein Kommentar
What is the part number for replacement motor? Where do you get it?
Paul Dias - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 3,747
