Einleitung
The Lasko 2002W fan motor can be replaced by the following guide.
Was du brauchst
Remove the 3 screws holding the fan on to the motor housing using a 3/16" philips head screw driver. The length of the screwdriver does not matter.
Remove the screws holding the motor onto the fan using the same 3/16" phillips head screwdriver. There are two screws.
Once removed, remove the metal part the screws were holding to the motor.
Remove the old motor from the fan. No tools are required. The motor can simply be pulled out.
Now that the old motor is removed, a new motor can be placed in the motor housing.
9 weitere Personen haben diese Anleitung absolviert.
