Zum Hauptinhalt wechseln
Le Pan II Camera Replacement
Was du brauchst
  1. Le Pan II Camera Replacement, Screen: Schritt 1, Bild 1 von 2 Le Pan II Camera Replacement, Screen: Schritt 1, Bild 2 von 2
    • Insert metal spudger between front and back panel to pry apart.
    • Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
    • Avoid using metal when opening devices, as it can damage or crack the screen.
  2. Le Pan II Camera Replacement: Schritt 2, Bild 1 von 2 Le Pan II Camera Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
    • Disconnect the flat ribbon by gently pulling it out from its connecting port.
  3. Le Pan II Camera Replacement: Schritt 3, Bild 1 von 2 Le Pan II Camera Replacement: Schritt 3, Bild 2 von 2
    • Use the plastic opening tool to disconnect the display cable from its motherboard connector.
    • Disconnect the display cable by gently pulling it out from its connecting port.
  4. Le Pan II Camera Replacement: Schritt 4, Bild 1 von 1
    • Remove grey metal backing from screen.
  5. Le Pan II Camera Replacement: Schritt 5, Bild 1 von 1
    • Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
  6. Le Pan II Camera Replacement: Schritt 6, Bild 1 von 1
    • Lift and carefully remove the LCD display from the front cover.
  7. Le Pan II Camera Replacement, Camera: Schritt 7, Bild 1 von 1
    • Use the plastic opening tool to lift the connector up and remove the camera.
Abschluss
Kelly Moniz
513 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 6-3, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 6-3, Martin Fall 2016
UMASSD-MARTIN-F16S6G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 80
