Einleitung
In this guide, you will be shown step-by-step how to replace your broken Le Pan II camera.
Was du brauchst
Insert metal spudger between front and back panel to pry apart.
Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
Disconnect the flat ribbon by gently pulling it out from its connecting port.
Use the plastic opening tool to disconnect the display cable from its motherboard connector.
Disconnect the display cable by gently pulling it out from its connecting port.
Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
Use the plastic opening tool to lift the connector up and remove the camera.
