Zum Hauptinhalt wechseln
Le Pan II Motherboard Replacement
Was du brauchst
  1. Le Pan II Motherboard Replacement, Screen: Schritt 1, Bild 1 von 2 Le Pan II Motherboard Replacement, Screen: Schritt 1, Bild 2 von 2
    • Insert metal spudger between front and back panel to pry apart.
    • Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
    • Avoid using metal when opening devices, as it can damage or crack the screen.
  2. Le Pan II Motherboard Replacement: Schritt 2, Bild 1 von 2 Le Pan II Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
    • Disconnect the flat ribbon by gently pulling it out from its connecting port.
  3. Le Pan II Motherboard Replacement: Schritt 3, Bild 1 von 2 Le Pan II Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Use the plastic opening tool to disconnect the display cable from its motherboard connector.
    • Disconnect the display cable by gently pulling it out from its connecting port.
  4. Le Pan II Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove grey metal backing from screen.
  5. Le Pan II Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
  6. Le Pan II Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Lift and carefully remove the LCD display from the front cover.
  7. Le Pan II Motherboard Replacement, Battery: Schritt 7, Bild 1 von 1
    • Use the plastic opening tool to push out the wires connecting the battery to the motherboard and put battery aside.
  8. Le Pan II Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 1
    • Use the Plillips 00 screwdriver head to unscrew the screws to the motherboard.
    • Reminder: There should 8 (3.5mm) screws
  9. Le Pan II Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Use the Phillips 00 screwdriver head to unscrew the screws to the fan.
    • Reminder: There should be 4 (1 mm) screws for the fan.
    • Note: From here, you can simply lift and remove the motherboard from the rest of the device.
Abschluss
Kelly Moniz
513 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 6-3, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 6-3, Martin Fall 2016
UMASSD-MARTIN-F16S6G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 175
