Einleitung
If the images taken are black or not displayed at all, it may be time to replace the camera. Replacing the camera is a moderately easy task, and the step-by-step disassembly is listed below. No out-of-the-ordinary tools will be required for this guide.
Was du brauchst
Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
Insert the spudger between the front and back panel in order to pry them apart.
Pry open the rest of the Le Pan S by dragging the spudger across the side.
Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
Remove the four 3.5 mm Phillips #00 screws from the circuit board near the bottom of the tablet.
Remove the zero insertion force connector (ZIF) by using a plastic opening tool, spudger, or fingernail to lift retaining flap.
