Zum Hauptinhalt wechseln
Leader Impression i10A-LE Back Facing Camera Replacement
Was du brauchst
  1. Leader Impression i10A-LE Back Facing Camera Replacement, Back Facing Camera: Schritt 1, Bild 1 von 2 Leader Impression i10A-LE Back Facing Camera Replacement, Back Facing Camera: Schritt 1, Bild 2 von 2
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Back Facing Camera Replacement: Schritt 2, Bild 1 von 3 Leader Impression i10A-LE Back Facing Camera Replacement: Schritt 2, Bild 2 von 3 Leader Impression i10A-LE Back Facing Camera Replacement: Schritt 2, Bild 3 von 3
    • Start by prying the back off by using plastic opening tools.
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Back Facing Camera Replacement: Schritt 3, Bild 1 von 3 Leader Impression i10A-LE Back Facing Camera Replacement: Schritt 3, Bild 2 von 3 Leader Impression i10A-LE Back Facing Camera Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Once the back is off, locate the back facing camera.
    • The camera will be in the top left corner.
    • Using the precision tweezers that are bent, gently grab the strip below the camera.
    • slowly lift up until the camera lifts from its spot.
  4. Leader Impression i10A-LE Back Facing Camera Replacement: Schritt 4, Bild 1 von 3 Leader Impression i10A-LE Back Facing Camera Replacement: Schritt 4, Bild 2 von 3 Leader Impression i10A-LE Back Facing Camera Replacement: Schritt 4, Bild 3 von 3
    • Continue slowly lifting with the bent precision tweezers.
    • The bottom half of the camera strip will pop out.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Crystal Dorrian
231 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 200
