Einleitung
This replacement guide will teach you how to remove and replace the back facing camera to your Leader Impression i10A-LE tablet. This fix can take anywhere from 15-25 minutes.
Was du brauchst
Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
Start by prying the back off by using plastic opening tools.
Using the plastic tools slide the flat end into the device.
Gently pry the back piece until you hear a popping noise.
Once the back is loose, remove it from the device and set aside.
Continue slowly lifting with the bent precision tweezers.
The bottom half of the camera strip will pop out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
