Zum Hauptinhalt wechseln
Leader Impression i10A-LE Battery Pack Replacement
Was du brauchst
  1. Leader Impression i10A-LE Battery Pack Replacement, Battery Pack: Schritt 1, Bild 1 von 1
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Battery Pack Replacement: Schritt 2, Bild 1 von 3 Leader Impression i10A-LE Battery Pack Replacement: Schritt 2, Bild 2 von 3 Leader Impression i10A-LE Battery Pack Replacement: Schritt 2, Bild 3 von 3
    • Use the plastic prying tools to crack open the back of the device.
    • Once cracked, use more plastic prying tools to fully remove the back panel. A popping noise will occur when each clip is opened.
    • Remove the back panel and set aside.
  3. Leader Impression i10A-LE Battery Pack Replacement: Schritt 3, Bild 1 von 2 Leader Impression i10A-LE Battery Pack Replacement: Schritt 3, Bild 2 von 2
    • The battery pack is glued to the device.
    • Use a spudger to pry the battery pack from the glue.
    • Desolder the positive (red) and negative (black) power leads.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 571
