Zum Hauptinhalt wechseln
Leader Impression i10A-LE Microphone Replacement
Was du brauchst
  1. Leader Impression i10A-LE Microphone Replacement, Microphone: Schritt 1, Bild 1 von 1
    • Orient your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Microphone Replacement: Schritt 2, Bild 1 von 3 Leader Impression i10A-LE Microphone Replacement: Schritt 2, Bild 2 von 3 Leader Impression i10A-LE Microphone Replacement: Schritt 2, Bild 3 von 3
    • Pry the back off by using plastic opening tools.
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Microphone Replacement: Schritt 3, Bild 1 von 2 Leader Impression i10A-LE Microphone Replacement: Schritt 3, Bild 2 von 2
    • Disconnect the positive and negative battery leads.
    • Remove the microphone from plastic housing with the tweezers.
    • Desolder the positive (red) and negative (black) power leads.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 108
