Zum Hauptinhalt wechseln
Leader Impression i10A-LE Speakers Replacement
Was du brauchst
  1. Leader Impression i10A-LE Speakers  Replacement, Speakers: Schritt 1, Bild 1 von 1
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Speakers  Replacement: Schritt 2, Bild 1 von 3 Leader Impression i10A-LE Speakers  Replacement: Schritt 2, Bild 2 von 3 Leader Impression i10A-LE Speakers  Replacement: Schritt 2, Bild 3 von 3
    • Start by prying the back off by using plastic opening tools
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Speakers  Replacement: Schritt 3, Bild 1 von 3 Leader Impression i10A-LE Speakers  Replacement: Schritt 3, Bild 2 von 3 Leader Impression i10A-LE Speakers  Replacement: Schritt 3, Bild 3 von 3
    • Use the spudger to pry both of the speakers from the tablet.
    • Follow both sets of speaker wires to the motherboard where they are connected.
    • Desolder the wire connections from the motherboard.
Abschluss
jcg
101 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 127
