Zum Hauptinhalt wechseln
LeapFrog LeapPad Platinum Motherboard Replacement
Was du brauchst
  1. LeapFrog LeapPad Platinum Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place your tablet on a flat surface with the screen facing down.
  2. LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 2, Bild 1 von 2 LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Using a plastic opening tool, pry off the plastic border by inserting it in the space between the green bumper and the white plastic on the edge of the tablet.
    • The border snaps into place, so don't be too worried if you hear a cracking noise while prying it off.
  3. LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 3, Bild 1 von 2 LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the 11 Phillips screws (8.0 mm) located around the edge of the back cover with a Phillips screwdriver.
  4. LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Pull the back cover off of your device.
  5. LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 5, Bild 1 von 3 LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 5, Bild 2 von 3 LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Wedge a plastic opening tool underneath the battery and lift the battery up.
    • The battery is held in place by an adhesive strip, so it can be difficult to pry off.
  6. LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 6, Bild 1 von 1
    • The battery has red, black, and white wires that are all connected to the motherboard through a plastic clip. Unplug this plastic clip to fully remove the battery from your device.
  7. LeapFrog LeapPad Platinum Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 2 LeapFrog LeapPad Platinum Motherboard Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Locate the white ribbon cable connected to the motherboard.
    • Disconnect the cable by flipping up the metal tab on the connector and sliding the cable out.
  8. LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 8, Bild 1 von 2 LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Locate the black ribbon cable which is connected to the motherboard.
  9. LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 9, Bild 1 von 2 LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Remove the three 4.0 mm Phillips screws located in the corners of the motherboard.
  10. LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Lift up the front edge of the motherboard.
    • Lift the volume-control button out of the device and set it aside.
  11. LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Gently tug upwards on the red and black twisted wires located near the button you just removed to release the black rubber base they are connected to from the device.
    • This does not take much force, so it is likely that this piece will pop out of place when initially lifting the motherboard.
  12. LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 12, Bild 1 von 2 LeapFrog LeapPad Platinum Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Rotate your device 180 degrees so the the motherboard is on your right-hand side and gently lift the front edge of the motherboard to reveal an orange sheet of plastic.
    • Disconnect the orange sheet from the motherboard by lifting the metal tab on the connector (as you did for the cables in steps 1 and 2), and lift the motherboard completely out of the device.
Abschluss
UW Tacoma, Team 1-5, Rose Winter 2016 Mitglied von UW Tacoma, Team 1-5, Rose Winter 2016
UWT-ROSE-W16S1G5
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 16
Insgesamt: 2,429
