Einleitung
Use this guide to remove all of the electrical components inside your LeapPad Platinum tablet and then replace the touch screen.
Was du brauchst
Using a plastic opening tool, pry off the plastic border by inserting it in the space between the green bumper and the white plastic on the edge of the tablet.
Remove the 11 Phillips screws (8.0 mm) located around the edge of the back cover with a Phillips screwdriver.
The battery has red, black, and white wires that are all connected to the motherboard through a plastic clip. Unplug this plastic clip to fully remove the battery from your device.
Locate the white ribbon cable connected to the motherboard.
Disconnect the cable by flipping up the metal tab on the connector and sliding the cable out.
Locate the black ribbon cable which is connected to the motherboard.
Remove the three 4.0 mm Phillips screws located in the corners of the motherboard.
Lift up the front edge of the motherboard.
Lift the volume-control button out of the device and set it aside.
Gently tug upwards on the red and black twisted wires located near the button you just removed to release the black rubber base they are connected to from the device.
Rotate your device 180 degrees so the the motherboard is on your right-hand side and gently lift the front edge of the motherboard to reveal an orange sheet of plastic.
Disconnect the orange sheet from the motherboard by lifting the metal tab on the connector (as you did for the cables in steps 1 and 2), and lift the motherboard completely out of the device.
Remove the brown speaker board located on the left side of the LeapPad by removing the following screws holding it in place:
Four 3.0mm Phillips screws
One 7.0mm Phillips screw
Locate the circular plastic speaker cover, remove the two 5.0mm Phillips screws holding it in place, and gently lift the cover away from the device.
Lift up the speaker board and locate the white ribbon attached to its underside.
Fully remove the speaker board from the device by gently pulling the ribbon cables out of the slot.
Remove the eight 4.0 mm screws for the plastic backing that covers the screen.
The screen is now completely accessible and can be lifted out of its cradle. Use the plastic spudger to safely and carefully lift the screen up.
2 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Where can i get a replacement screen?
