Zum Hauptinhalt wechseln
LeapFrog LeapPad Ultimate Back Panel Replacement
Was du brauchst
  1. LeapFrog LeapPad Ultimate Back Panel Replacement, Back Panel: Schritt 1, Bild 1 von 2 LeapFrog LeapPad Ultimate Back Panel Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate Back Panel Replacement: Schritt 2, Bild 1 von 2 LeapFrog LeapPad Ultimate Back Panel Replacement: Schritt 2, Bild 2 von 2
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 20
Letzte 30 Tage: 56
Insgesamt: 1,607
