Einleitung
A guide on how to replace the camera in a LeapFrog LeapPad Ultimate.
Was du brauchst
Flip over the Pad to its back side to begin the removal of the back panel.
Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
Once the blue rim is removed, the 12 screws will be visible.
Use the Phillips #1 screwdriver to unscrew all 12 screws.
Remove the ribbon on the bottom of the motherboard and the ribbon on the left side of the motherboard.
Flip the motherboard to its back side and pinch the 2 green hooks to remove the camera cover
Remove the ribbon connecting the camera to the motherboard. You have now taken out the camera and can replace it with a new one.
