Einleitung
The screen of any device is one of the most delicate parts. This guide will walk you through how to replace your LCD screen.
Was du brauchst
Flip over the Pad to its back side to begin the removal of the back panel.
Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
Once the blue rim is removed, the 12 screws will be visible.
Use the Phillips #1 screwdriver to unscrew all 12 screws.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
The segment connecting the battery to the motherboard will consist of red, white, and black wires.
There is a small notch on the segment. Use the curved tweezers to pull the notch in the direction of the battery. this will disconnect the battery from the motherboard.
Carefully remove the battery from its place and set aside.
Removing the battery will fully expose a white and blue ribbon cable that runs beneath the battery.
The ribbon cable must be disconnected from the motherboard and removed from the panel.
The ZIF connector which connects the ribbon cable and the motherboard has a small flap on the top.
Use the curved tweezers to to flip the flap up.
Once it is disconnected, carefully pull the ribbon cable through the 2 black plastic arches holding it down.
Use a Phillips #1 screwdriver to unscrew the 7 screws on the speaker.
5 will be on the brown part and 2 on the circular blur part.
Once it is unscrewed completely, remove the speaker and set aside.
An orange and black ribbon cable connects the motherboard and the area to the side of the panel.
There is a switch on top of it.
Use the curved tweezers to flip the switch.
Flip the motherboard over to expose the uderside.
There is a wide black ribbon with a swtich. Flip the switch and set aside the motherboard.
Along the side of the blue panel are 6 screws. Unscrew each of the screws with a Phillips #1 screwdriver.
Remove the panel and the remainder of its contents and set aside.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Where did you find a Replacement screen? Are there any identifying part numbers?
