Zum Hauptinhalt wechseln
LeapFrog LeapPad Ultimate LCD Screen Replacement
Was du brauchst
  1. LeapFrog LeapPad Ultimate LCD Screen Replacement, Back Panel: Schritt 1, Bild 1 von 2 LeapFrog LeapPad Ultimate LCD Screen Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
    Frag FixBot
    Kommentar hinzufügen
  2. LeapFrog LeapPad Ultimate LCD Screen Replacement: Schritt 2, Bild 1 von 2 LeapFrog LeapPad Ultimate LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
    Frag FixBot
  3. LeapFrog LeapPad Ultimate LCD Screen Replacement, LCD Screen: Schritt 3, Bild 1 von 3 LeapFrog LeapPad Ultimate LCD Screen Replacement, LCD Screen: Schritt 3, Bild 2 von 3 LeapFrog LeapPad Ultimate LCD Screen Replacement, LCD Screen: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • The segment connecting the battery to the motherboard will consist of red, white, and black wires.
    • There is a small notch on the segment. Use the curved tweezers to pull the notch in the direction of the battery. this will disconnect the battery from the motherboard.
    • The battery is the bright orange rectangle.
    • The motherboard is the large dark green surface.
    Frag FixBot
  4. LeapFrog LeapPad Ultimate LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Carefully remove the battery from its place and set aside.
    • Removing the battery will fully expose a white and blue ribbon cable that runs beneath the battery.
    • The ribbon cable must be disconnected from the motherboard and removed from the panel.
    Frag FixBot
  5. LeapFrog LeapPad Ultimate LCD Screen Replacement: Schritt 5, Bild 1 von 2 LeapFrog LeapPad Ultimate LCD Screen Replacement: Schritt 5, Bild 2 von 2
    • The ZIF connector which connects the ribbon cable and the motherboard has a small flap on the top.
    • Use the curved tweezers to to flip the flap up.
    • Once it is disconnected, carefully pull the ribbon cable through the 2 black plastic arches holding it down.
    Frag FixBot
  6. LeapFrog LeapPad Ultimate LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Use a Phillips #1 screwdriver to unscrew the 7 screws on the speaker.
    • 5 will be on the brown part and 2 on the circular blur part.
    • Once it is unscrewed completely, remove the speaker and set aside.
    Frag FixBot
  7. LeapFrog LeapPad Ultimate LCD Screen Replacement: Schritt 7, Bild 1 von 1
    • An orange and black ribbon cable connects the motherboard and the area to the side of the panel.
    • There is a switch on top of it.
    • Use the curved tweezers to flip the switch.
    Frag FixBot
  8. LeapFrog LeapPad Ultimate LCD Screen Replacement: Schritt 8, Bild 1 von 1
    • Unscrew the 3 screws on the motherboard with a Phillips #1 screwdriver.
    Frag FixBot
  9. LeapFrog LeapPad Ultimate LCD Screen Replacement: Schritt 9, Bild 1 von 2 LeapFrog LeapPad Ultimate LCD Screen Replacement: Schritt 9, Bild 2 von 2
    • Flip the motherboard over to expose the uderside.
    • There is a wide black ribbon with a swtich. Flip the switch and set aside the motherboard.
    Frag FixBot
  10. LeapFrog LeapPad Ultimate LCD Screen Replacement: Schritt 10, Bild 1 von 2 LeapFrog LeapPad Ultimate LCD Screen Replacement: Schritt 10, Bild 2 von 2
    • Along the side of the blue panel are 6 screws. Unscrew each of the screws with a Phillips #1 screwdriver.
    • Remove the panel and the remainder of its contents and set aside.
    Frag FixBot
  11. LeapFrog LeapPad Ultimate LCD Screen Replacement: Schritt 11, Bild 1 von 1
    • The screen is now exposed and can be removed and replaced.
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Where did you find a Replacement screen? Are there any identifying part numbers?
Johan Rodriguez - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 69
Insgesamt: 5,531
