Zum Hauptinhalt wechseln
LeapFrog LeapPad Ultra Repair Motherboard Replacement
Was du brauchst
  1. LeapFrog LeapPad Ultra Repair Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapFrog LeapPad Ultra Repair Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapFrog LeapPad Ultra Repair Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapFrog LeapPad Ultra Repair Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapFrog LeapPad Ultra Repair Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra Repair Motherboard Replacement: Schritt 6, Bild 1 von 2 LeapFrog LeapPad Ultra Repair Motherboard Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
  7. LeapFrog LeapPad Ultra Repair Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 3 LeapFrog LeapPad Ultra Repair Motherboard Replacement, Motherboard: Schritt 7, Bild 2 von 3 LeapFrog LeapPad Ultra Repair Motherboard Replacement, Motherboard: Schritt 7, Bild 3 von 3
    • Disconnect the three wires that will be visible on top of the motherboard. The wires need to be disconnected by pulling them up vertically.
  8. LeapFrog LeapPad Ultra Repair Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Unscrew the five screws holding the motherboard into the housing.
  9. LeapFrog LeapPad Ultra Repair Motherboard Replacement: Schritt 9, Bild 1 von 3 LeapFrog LeapPad Ultra Repair Motherboard Replacement: Schritt 9, Bild 2 von 3 LeapFrog LeapPad Ultra Repair Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Lift the motherboard up exposing the fourth and final wire. Once you lift up the motherboard you will need to pull down on the wire to disconnect.
  10. LeapFrog LeapPad Ultra Repair Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Remove and replace motherboard.
Abschluss
Rocky Hirsch
902 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 4-99, Meier Fall 2015 Mitglied von USF Tampa, Team 4-99, Meier Fall 2015
USFT-MEIER-F15S4G99
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 1,850
