Zum Hauptinhalt wechseln
LeapFrog LeapPad Ultra Repair Screen Replacement
Was du brauchst
  1. LeapFrog LeapPad Ultra Repair Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapFrog LeapPad Ultra Repair Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapFrog LeapPad Ultra Repair Screen Replacement: Schritt 3, Bild 1 von 1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapFrog LeapPad Ultra Repair Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapFrog LeapPad Ultra Repair Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra Repair Screen Replacement: Schritt 6, Bild 1 von 2 LeapFrog LeapPad Ultra Repair Screen Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
  7. LeapFrog LeapPad Ultra Repair Screen Replacement, Motherboard: Schritt 7, Bild 1 von 3 LeapFrog LeapPad Ultra Repair Screen Replacement, Motherboard: Schritt 7, Bild 2 von 3 LeapFrog LeapPad Ultra Repair Screen Replacement, Motherboard: Schritt 7, Bild 3 von 3
    • Disconnect the three wires that will be visible on top of the motherboard. The wires need to be disconnected by pulling them up vertically.
  8. LeapFrog LeapPad Ultra Repair Screen Replacement: Schritt 8, Bild 1 von 1
    • Unscrew the five screws holding the motherboard into the housing.
  9. LeapFrog LeapPad Ultra Repair Screen Replacement: Schritt 9, Bild 1 von 3 LeapFrog LeapPad Ultra Repair Screen Replacement: Schritt 9, Bild 2 von 3 LeapFrog LeapPad Ultra Repair Screen Replacement: Schritt 9, Bild 3 von 3
    • Lift the motherboard up exposing the fourth and final wire. Once you lift up the motherboard you will need to pull down on the wire to disconnect.
  10. LeapFrog LeapPad Ultra Repair Screen Replacement: Schritt 10, Bild 1 von 1
    • Remove and replace motherboard.
  11. LeapFrog LeapPad Ultra Repair Screen Replacement, Screen: Schritt 11, Bild 1 von 2 LeapFrog LeapPad Ultra Repair Screen Replacement, Screen: Schritt 11, Bild 2 von 2
    • Remove the side grips simply pulling them both vertically exposing eight screws.
  12. LeapFrog LeapPad Ultra Repair Screen Replacement: Schritt 12, Bild 1 von 1
    • Using the screwdriver with the PH1 bit, unscrew all nine of the exposed screws holding the plastic base down and remove the base.
  13. LeapFrog LeapPad Ultra Repair Screen Replacement: Schritt 13, Bild 1 von 1
    • Using the screwdriver with the PH00 bit, unscrew the twelve screws holding the screen casing down.
  14. LeapFrog LeapPad Ultra Repair Screen Replacement: Schritt 14, Bild 1 von 1
    • Separate the screen from the casing and circuit board.
  15. LeapFrog LeapPad Ultra Repair Screen Replacement: Schritt 15, Bild 1 von 1
    • Replace screen.
Abschluss
11 weitere Personen haben diese Anleitung absolviert.
Rocky Hirsch
902 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 4-99, Meier Fall 2015 Mitglied von USF Tampa, Team 4-99, Meier Fall 2015
USFT-MEIER-F15S4G99
4 Mitglieder
10 Anleitungen geschrieben
8 Kommentare zur Anleitung
I need a source for the LCD screen. Anyone have a connection?
rhilscher - Antwort
Where would i purchase the new screen?
gaildavies282 - Antwort
You cannot get the screens. I had to get one from a parted device. Best you could try for is finding one the correct size with the connector in the proper place that is 50 pin.
crhouk - Antwort
I bought mine on eBay for 15.00.
Joel Marcarelli - Antwort
Could you send the link to where you bought yours
Michelle Popoff -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 22
Letzte 30 Tage: 174
Insgesamt: 16,938
